Help with building my pc
Vibrus
13
So I am looking to build a gaming pc for around 1500 USD that has the following parts. i7 7700k processor with Nvidia 1070 or 1080 GPU and a 16 GB ram and 2 1TB HDDs as well. So I need help with the rest of the parts as I have no clue of what to pick and what motherboard fits these. so if anyone can suggest a motherboard that is preferably gigabyte if possible, a power supply, cooling unit, and a cool looking high tower case that is see through that is all around 1500 USD I would appreciate it. (If it isn't possible to be around $1500 give me other suggestions please)
PCPartPicker part list: https://pcpartpicker.com/list/nxfR4q
Price breakdown by merchant: https://pcpartpicker.com/list/nxfR4q/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($339.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 LED 66.3 CFM Rifle Bearing CPU Cooler ($24.89 @ OutletPC)
Motherboard: ASRock - H370 Pro4 ATX LGA1151 Motherboard ($92.74 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($158.99 @ Newegg)
Storage: Crucial - MX500 1TB M.2-2280 Solid State Drive ($219.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($43.90 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card ($469.99 @ Amazon)
Case: NZXT - Source 530 ATX Full Tower Case ($79.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ Newegg)
Total: $1505.37
Generated by PCPartPicker 2018-06-23 11:33 EDT-0400
i7 7700k was introduced January 3, 2017 and is not one of Intel's current 8th Generation Intel Core processors.
With a "k" CPU, you would want a Z270 Chipset model. Not all of the Gigabyte models from 2017 are still sold but some are. Unfortunately, you seem unable to use Gigabyte Compare Tool and don't know what features are different.
https://www.gigabyte.com/au/Comparison/Result/2?pids=6072,6095
GIGABYTE GA-Z270X-Ultra Gaming
https://www.newegg.com/Product/Product.aspx?Item=9SIA85V5J87069
DDR4-2400MHz memory (higher speeds are commonly used when overclocking)
https://www.newegg.com/Product/Product.aspx?Item=N82E16820313518&Tpk=N82E16820313518
You wrote you have "a 16 GB ram". I couldn't tell you if that will work based on such a vague description.
Seasonic FOCUS series SSR-650FM 650W 80 + Gold Power Supply
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151202
Cooler Master MasterLiquid 240 AIO CPU Liquid Cooler
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103234&Tpk=N82E16835103234
A minimum of 240mm is recommended, as smaller 120mm won't have adequate cooling.
Cooler Master N400 NSE-400-KKN2 N-Series Mid Tower Computer Case
https://www.newegg.com/Product/Product.aspx?Item=N82E16811119277
If you want to use a liquid CPU cooler, be sure to pick case that states it will fit the radiator.
