Build Advice Help =) with building on my First AMD. Ryzen 5 3400G and Micro ATX..... so confused
Feb 8, 2020
7
Good evening everyone! Its been a long long time, about 10 years since my last system build. I thought I have done enough research and ordered most of the parts.... Well. I guess I didnt and I am sure I didnt get a good match on MB and Memory.... All the parts I have are still unopened and can be exchanged.
Goal for this sytems is to be Downstairs/Kitchen Counter/Streaming/Little Video Editing/Very light Gaming
I want to build mATX system with Phanteks EVOLV mATX Tempered Glass Case.
Parts Ordered:
AMD Ryzen 5 3400G - Returned Unopened
EVGA G5 650
Fully Modular PS - Returned Unopened After More Research
Samsung 970 Evo Plus SSD 250GB M.2 NVMe
Killer Wi-Fi 6 AX1650
with BT5.0 M.2
ASRock X570M PRO4 AM4 AMD X570 SATA 6Gb/s Micro ATX AMD Motherboard
Update 2/14:
.... Well. What first stared as a budget build... turned into full build... that quickly trippled the price LOL.
Thank you everyone and I will post the full build later.
7
Ok. Looks like X570 is not a bad choice.
Correct me if I am wrong.
After looking at B-Die Finder and then Bouncing the Part number off the G.Skill Website MB Compatibility list.
I am coming up with
G.Skill Flare XF4-3200C14D-16GFX3200C14
For 2x8GB RAM for Razen 5 3400G CPU and ASRock X570M Pro4 mATX board.
Anything I am missing? Anything Different can be done?
I am coming up with
You don't really need a b-die memory unless you want to OC it much higher,
All X570 chipset are 3rd gen Ryzen compatible.
