Hi,
My mother in law accidentally plugged her external hard drive into a laptop charger because the plugs fit. The actual HDD ac adapter is 12 volts, the laptop one is 24 volts.
The pcb that converts sata to usb is completely burnt with black spots.
I tried to plug the HDD alone in the pc but it wont spin.
I took the HDD pcb and it doesnt seem to have any obvious burn marks althought it smells a little bit different.
Could the hdd be still alive internally? Is it worth trying to replace the pcb.
How could the overvoltage pass through both pcb's if the first one burnt.
Thanks
Thanks
