Help with burnt RAM
Mercy_18
What if you accidentally took of the RAM while the computer was on what do you think burnt in the process because the was this funny smell
Then you likely accidentally tore your ram up, with a decent possibility you tore your ram slot up, and a slight possibility you ruined the memory controller on the CPU or motherboard (depending on the build) to the point you'd need nearly and entire new build to fix it.
Or EVERYTHING may be fine. However I suspect if you're here you've already tried to put it back in and it didn't?
