help with buying a power supply
Japp__
Commendable
Jul 27, 2016
[noob alert] So i am planning to upgrade my gpu from gt610 to gtx960.the trouble i am having is i dont know about the power supply's connectors to mobo.i have a gigabyte mobo ( http://www.gigabyte.in/products/product-page.aspx?pid=4305#ov ) which has a 8 pin atx connector.but i am currently using it with a 4pin atx connector 350w power supply.and my gpu gt 610 does not require any additonal power.but the gtx 960 requires a 6 pin pci-e connector.so do now i have to buy a power supply with full 8 pin atx connector + 6 pin atx connector or otherwise.
thanks in advance
could u suggest me a psu with these kind of connectors as i have to buy a new one due to wattage.
EVGA is a good brand, reliable PSUs. You probably won't need more than a 450 watt PSU for the 960, any of the newer EVGA PSUs should have all the cables you need. Any of them under 600 watt won't be fully modular though (you can plug in just the cables you need with a fully modular PSU).
