I'm pretty sure this belongs in this section. Earlier this year I put together a build with a Cooler Master Silencio 352. I really like the case, but recently upgraded my GPU from an r9 280 to an MSI r9 390, and it appears to have issues providing enough airflow for such a hot card. When I run a taxing game such as Witcher 3, the GPU runs up to the mid-90s (at which point I quit the game). However, when I take the side of my case off, it tops off around 82 degrees.
The case comes stock with two XtraFlo fans (one intake in the front, one out in the rear). I added another (albeit small) fan to the front for better intake, but it didn't seem to help. There isn't much room for other fans (the one at the top would be blocked by my CPU cooler).
My question is this: could the problem be remedied by simply replacing the stock fans with higher quality fans, or should I look into getting a new case better fitted to deal with the heat? If so, what might be a good case to look at purchasing (mobo is mATX)?
Let me know if any more info is needed.
