I have been looking to change the fans in my case but I'm not very knowledgeable about fans so i dont know what to look for when choosing new fans. I heard that noctua fans were good so i had a look at the and compared them to the majority of other fans. I found some akasa fans that seem to be good but there are a few things i am unsure of:
- firstly are they actually good? i have little knowledge so i want other people's opinions
- It says that they are 140mm fans with 120mm fittings. does this mean it will fit on a h100i?
- if they do fit on the h100i will they do a good job at cooling?
- i watch linus tech tips and he said that he preferred the high static pressure fans as all of his case fans. Is this a good thing to do or not because i was thinking of just using these fans for all of my case fans.
These are the fans i have been looking at:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-074-AK&groupid=701&catid=2331&subcat=4
Thanks for any help you can give me
