Help with case, First Build
Ddily
Hello, After a bit of research, I decided to build a computer. Everything is working pretty well, Except the front fan on the case makes a loud clicking noise. The case in a Xclio A380 Color, and I'd would appreiciate any help you can provide.
Is the sound continuous.? In that case the fan blades might be touching on some wire or some other stuff while in motion.. The noise may be electrical also in which case you should check the fan power connector.. If it uses a standard molex then try using some other molex connector..
