T technub Honorable Feb 3, 2013 47 0 10,530 May 8, 2014 #1 Okay so I have a antec mid size tower case and i cant get my gtx 780 to fit in it :/ Wat case can i buy for it? do i need a full tower case?
RazerZ Judicious Aug 18, 2013 9,961 0 33,960 May 8, 2014 #2 Which case do you have? Did you already try removing drive bays to make it fit? Upvote 0 Downvote
T technub Honorable Feb 3, 2013 47 0 10,530 May 8, 2014 #3 I have this case atm http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066 Upvote 0 Downvote
MalakiArtook Honorable Mar 5, 2014 1,374 0 11,660 May 8, 2014 #4 just take out the drive bays where it is hitting you dont need them. Upvote 0 Downvote
RazerZ Judicious Aug 18, 2013 9,961 0 33,960 May 8, 2014 #5 Are you sure it doesn't fit? The 300 illusion should fit a full sized graphics card. Upvote 0 Downvote
garrettk4 Honorable May 31, 2012 432 0 10,810 May 8, 2014 #6 If I'm not mistaken, the drive cages in the 300 illusion are not removable. Upvote 0 Downvote
RazerZ Judicious Aug 18, 2013 9,961 0 33,960 May 8, 2014 #7 garrettk4 : If I'm not mistaken, the drive cages in the 300 illusion are not removable. Ah I think you're right from the pics of the interior I can see. Upvote 0 Downvote
RazerZ Judicious Aug 18, 2013 9,961 0 33,960 May 8, 2014 #8 Source 220: $45 http://pcpartpicker.com/part/nzxt-case-caso22001 Upvote 0 Downvote
MalakiArtook Honorable Mar 5, 2014 1,374 0 11,660 May 8, 2014 #9 garrettk4 : If I'm not mistaken, the drive cages in the 300 illusion are not removable. Well... I'd beg to differ. 😛 Upvote 0 Downvote
T technub Honorable Feb 3, 2013 47 0 10,530 May 8, 2014 #10 So i can remove the drive bays? they dont look removable Upvote 0 Downvote
RazerZ Judicious Aug 18, 2013 9,961 0 33,960 May 8, 2014 #11 technub : So i can remove the drive bays? they dont look removable Check the manual to see if you can. If not and you are good with tools, you could use a dremel to cut out a slot to fit the 780. Upvote 0 Downvote
MalakiArtook Honorable Mar 5, 2014 1,374 0 11,660 May 8, 2014 #12 they probably are not then. doesn't mean you cant remove them. cut it out with a dremel, jig, tin snips, w/e Upvote 0 Downvote
