Hi guys,
In my PC I want my case fans to run a bit faster, or just in general have some sort of control over my case fans. My problem is I'm not sure which fan is which. All I see in SpeedFan is Fan 1-5, and these don't correspond to the fan numbers on the motherboard. I would change one of these to 0%, just for seeing which one stops, therefore indicating which fan number that is. I don't do this because I am too worried about shutting off my CPU fan or a GPU fan, and possibly causing some damage. Can someone help me as to find which number corresponds to which case fan, is having my CPU fan turned off for a minute cause some damage?, and how do I quickly revert my settings to defaults when using SpeedFan.
Note: One fan is constantly running at about 450rpm whereas the other one is running at about 1100rpm. Does this indicate anything, as I have one 120mm exhaust fan, and one 240mm intake fan?
Thanks for you help.
