Help with choice of PSU.
If you haven't committed to those parts yet, I would swap out the memory. Good modules and all, but the tall heat spreaders aren't needed and they have high voltage (1.65). For gaming look toward DDR3-1600 CL7 or CL8 modules (gaming software won't see a difference in memory speeds). If you will be doing other productivity work, look for DDR3-1866 CL9 (low latency). At the moment pricing looks like the modules below are the best bang for-the-buck. On the PSU front, the EVGA Supernova series is good and there are others as well, but just stick with the tried-and-true manufacturers in XFX or Seasonic. 550w for a single GPU, or up that to a 750w if you want to add a second 780 Ti down the road.
MEM => http://pcpartpicker.com/part/gskill-memory-f31866c9d16gxm
PSU => http://pcpartpicker.com/parts/power-supply/#m=71,39&W=550,860&e=4,2&sort=a9
@tiny Voices I already purchased it, and its shipping out, so lets just put that one in the bag and say i made the mistake, what could i do about that graphics card, im just looking for something to max out settings on a 1080 for a few years and on.
Ok thanks for the help guys. Now i just cant figure out which ram to choose from, maybe someone can list 1 for me? Or does the listed below do well? I just heard Corsair is a good ram to use
