Help with choosing a case
louis_rothwell
Commendable
Dec 27, 2016
I need help with choosing a case for this build:
Intel Core i7-6700K 4.0GHz Quad-Core Processor
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Gigabyte GA-Z170X-Gaming 7 ATX LGA1151 Motherboard
Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Gigabyte GeForce GTX 1080 8GB G1 Gaming Video Card
EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply
I am not really sure what is best to look for in a case and would appreciate any advice!
a few case if you're into showing it off
http://pcpartpicker.com/product/gwzZxr/nzxt-case-cah442wm1
http://pcpartpicker.com/product/NRvZxr/phanteks-case-phes515etgbk
http://pcpartpicker.com/product/J2yFf7/corsair-case-500rbk
I have the H440
[/URL][/img]
The question is what are you after, are you looking for a small compact case where everything fits snuggly inside or are you looking for a big tower with lots of room to upgrade eg, add extra graphics cards or custom water cooling
After that you need to consider what style your going for, Windows or not ( tip if you have windows it will eventually look sexy af but it may be more expensive in the long run since you'll wanna go for a colour theme or leds so it looks good, you'll also have to cable manage), do you want it to look clean and simple or do you want it to be angular or futuristic
Once you no what style your after your gonna want to think about future proofing and other things like how many fans or ports/drive bays
Nzxt h440 is the case I have...
