---Edit--- I have decided to go all out and get a DDR4 motherboard, does anyone have a suggestion for a good DDR4 motherboard $100 - $200 that is compatible with I7 7700?
I have an i7 7700 CPU, and currently own 4 sticks of 4gb DDR3 ram (16gb total).
(more detailed specs below)
I was thinking of getting this motherboard: https://www.amazon.com/Asus-LGA1151-MicroATX-Motherboards-D3/dp/B013HIEWGE/ref=sr_1_2?ie=UTF8&qid=1526782284&sr=8-2&keywords=Asus+-+B150M-A+D3+Micro+ATX+LGA1151+Motherboard
I need help choosing whether I should go with this motherboard that supports the ram I currently own, or whether I should just go for a DDR4 motherboard and buy DDR4 ram (might be out of my price range). I'm willing to pay up to ~$200 for a motherboard. I am looking for motherboard recommendations, and advice.
I am not even sure if the motherboard I linked supports the i7 7700 CPU, I don't know how to tell.
More detailed specs of my current pc's Memory:
Type DDR3
Size 16384 MBytes
Channels # Dual
DRAM Frequency 722.4 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Bank Cycle Time (tRC) 34 clocks
Slot 1: Type: DDR3 - Size: 4096 MBytes - Manufacturer: Corsair
Slot 2: Type: DDR3 - Size: 4096 MBytes - Manufacturer: Corsair
Slot 3: Type: DDR3 - Size: 4096 MBytes - Manufacturer: Corsair
Slot 4: Type: DDR3 - Size: 4096 MBytes - Manufacturer: Corsair
Here's the CPU I have: https://www.amazon.com/gp/product/B01N0L41N7/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Type DDR3
Size 16384 MBytes
Channels # Dual
