Question Help with choosing a motherboard
May 11, 2019
I recently bought a case (corsair spec delta) and im looking to upgrade my pc, but step by step and i want to start with the motherboard, my mother board doesn't support my case rgb fans,(3 rgb fans and 1 normal fan) so i want something good that supports my fans and also in the budget of 40-60$
List of my current hardware
https://pcpartpicker.com/list/zzfzQZ
I recently bought a case (corsair spec delta) and im looking to upgrade my pc, but step by step ... in the budget of 40-60$
I think it's safe to say any motherboard for that Intel processor, in that budget range, will leave you next to zero upgrade paths. Zero if you expect to upgrade to anything meaningful.
I have to say though, your's is the first time I've ever seen someone using their RGB fans as the starting point for an upgrade path. They must be awesome.
