Question Help with choosing between these three monitors
Mar 4, 2019
Hi everyone, I would massively appreciate your help in choosing an IPS monitor.
I don't use the PC for gaming so response time etc is not that important. What's important are good viewing angles and faithful colour reproduction as I do a lot of Photoshopping. And budget.
I've narrowed it down to three similarly priced contenders:
Iiyama ProLite XU2492HSU B1
Dell S2419HN
LG 24MK600M
I'm veering towards the LG as it's colour calibrated out of the box, has a VESA mount.
But as I said, viewing angles and picture quality are the most important factors.
Thanks for all the advice !
If you can solve the reflective issue with a gloss front panel(found on the Dell) with the aid of controlled lighting and placement around your room (and not behind a window) then I'd suggest the Dell monitor, otherwise you're on the right direction with LG's offering.
