Question Help with choosing CPU air cooler
m-one
5
Hello all,
I need to upgrade my PC and I am currently looking for a CPU air cooler. The case I already own Bitfenix Pandora Core allows to connect 3 fans in total ( currently as 2 of them at front case, sucking air in and one exhaust fan at the top ).
Considering the air flow, which CPU cooler mount would you prefer? A horizontal or vertical mount? Does it make any difference?
Also, if I get a horizontal CPU cooler which size is very close to the limit suggested by the manufacturer, do you think that the hot air can be bounced back from the side panel towards the motherboard without being effective?
Thanks a lot
