Help with choosing my Upgrade Path!
Arodoul
Hey guys, I come here all the time for solutions to my problems. But this is the first time I've ever posted here.
My current setup is;
CPU: FX 6300 @ 4.2Ghz overclocked
Cooler: Coolermaster Hyper 212 EVO
GPU: Sapphire R9 270x Vapor X OC Edition 2GB
Mobo: AsRock Extreme3 970 R2.0
PSU: 750w Thermaltake Smart Power
RAM: 2 x 4GB G.Skill 1866hz memory
HDD: 240GB Crucial M500 SSD + WD Blue 500GB HDD
I play World of Warcraft on an almost daily basis and this is by the most regular game I play, though I play many other games too. Including many modern FPSes and other genres.
What I'm curious about is what my next Upgrade should be, I've looked around at different GPUs, CPUs on the AM3+ Socket and Intel CPUs too. My current thought process is that I should upgrade my CPU to the i5 4690k first, because games like World of Warcraft, a relatively old MMO, are quite CPU bound and are limited in their multi-core utilization.
Though I am unsure as to whether it would make a major difference in the game or not. Or even if it did, would it make more of a difference than me upgrading to something along the lines of an R9 290x?
At the moment playing WoW @ 1080p and ultra / high settings I can manage around 60+FPS, although when I get into 25 Man raids my FPS can end up tankign to around 25FPS, sometimes slight jittering aswell. I don't know whetther that would be because the CPU isn't capable enough or because I expect too much out of the graphics card. Hence why I'm here.
So in conclusion, I'm stuck as to whetehr I should upgrade to the i5 4690k / i5 4460 / sometihng along that price range. Or whether I should upgrade my GPU to something like the R9 290x. Help? Bearing in mind that although I play many games, world of Warcraft is my top played by far.
Indeed, though the issue is that with MMOs such as World of Warcraft they tend to be pretty CPU bound. Really old engine that benefits more from single threaded performance than most games. Hence my concern.
i would suggest the CPU first ,but for that you need tto change your entire rig if it is ok with you
1. not sure but i think the no. of persons is a CPU thing.
2. CPUs are more worthwhile investments than GPUs
.get a i5 446o for the price. (or fx8350 if you dont want mobo upgrades)
3.If you can wait there is going to be a whole new gen of CPUs and GPUs (wait till amd 300 is released , then there will be pricedrops on both nvidia and amd sides)
PS- this might sound a bit crazy, but i recommend going for more than 4 core processors on intels side(a xeon?)
And try not opting for amds , they have the numbers but not the actual efficiency(not sure if it is the right word)
I probably could wait, though I have no intention in lowering my graphics settings to recieve perfect frames in raids. I think I will end up upgrading my CPU. do you think I'd see a tangible performance boost, particularly in raids?
