Hi.
Can you help me with the following build, I want to know if everything is compatible with each other?
I don't know if it is.
Mobo: Gigabyte B650 Gaming X AX
CPU: AMD Ryzen 7 7700X 8-Core (4.5GHz-5.4GHz) 40MB AM5
SSD: Kingston KC3000 2TB Gen4 M.2 NVMe 2280
RAM: G.Skill Kit 32GB (2 x 16GB) DDR5 6000MHz Flare X5 EXPO CL32 Black
GPU: ASRock Radeon RX 7800 XT Challenger OC 16GB GDDR6
Case: ATX Montech AIR 903 Base Preto
PSU: Modular Corsair RMx Series RM1000e 1000W 80 Plus Gold ATX3.0
CPU Cooler: Deepcool AK620 Zero Dark or Artic Freezer 34 eSports Duo
Also, I have this one too:
Mobo: Motherboard Asus Prime B760M-A WiFi
Case: Micro-ATX Montech AIR 100 ARGB Vidro Temperado Preto
CPU: Processador Intel Core I5-13400F 10-Core (2.5GHz-4.6GHz) 20MB Skt1700
WaterCooler: Water Cooler CPU EKWB AIO 120 D-RGB
RAM: Team Group Kit 32GB (2 x 16GB) DDR5 5600MHz Delta RGB Preto CL36
GPU: Gráfica MSI GeForce® RTX 4070 VENTUS 2X OC 12GB GDDR6 DLSS3
SSD: Disco SSD Team Group MP34 1TB M.2 NVMe
PSU: Fonte MSI MAG A650BN 650W 80+ Bronze
Are either of them any good for gaming and work?
