Help with components for build
BEEANNER
7
Good day all. Needing a few recommendations on a few components for my build please. I'm not a huge over clocker, but would like to start learning. More of a build it and lets roll type of person. Looking to build a decent gaming pc on a mid size budget. Trying to keep it on a budget of around 500.00 or less for the components I have left atm.
Forgot to mention when I originally posted this. I am pulling the current proc and video card out of an alienware x51 machine I own.
I have the following and would like to continue using them if possible:
Intel I7 4790 lga 1150 processor
GeForce 760 TI video card.
Fractal Design Integra M 650w power supply
Corsair 240gb SSD
WD 7200prm 1tb drive
Cooler Master N200 Micro ATX case.
Needing help on a micro atx board, memory, and cpu cooler. I can dump the micro atx case if need be to get a better board. I have no pref on brand as well.
Any recommendations would be greatly appreciated!!
Probably would have helped to mention I'm pulling the current proc and video card out of an alienware pc I own. Hence the reason I was considering a new board and memory.
I'd still just leave it in the Alienware. The motherboard will give you no benefit. Even a new CPU/board will be a very minor upgrade. A 760 ti uses as much power as a 1070 so the power supply should be fine (as long as it has required connectors) that doesn't change my recommendation one bit
Awesome!!! Thank you very much for the help! Its much appreciated!
