Recently retired early from supporting OS's and networks for 36 years going back to an IBM/360 with a whole 32k of memory. I have worked with various hardware over the years but never built from scratch.
I want to build a machine that will last awhile(wife's requirement) that I can use to upload and edit video from old tapes. I don't need a high end gaming machine but do want to be able to upgrade down the road.
In researching hardware between performance, cost, and ability to upgrade later, this is what I have so far for the base parts.
Antec Sonata II Case 450 watt PS
AMD AM2 X2 Athlon64 XP4200+ 1024k
2GB DDR2-667 Crucial Memory
SATA II Drives
Use existing DVD I have
I'm stuck on picking a motherboard to support the above. Onboard graphics and add video card later or add now? Is this overkill for what I want to do? I used an All-in-Wonder in the old machine.
Comments/Suggestions on a motherboard and this configuration would be GREATLY appreciated.[/list]
SATA II Drives
