Question Help with connecting 5.1 to PC
Apr 3, 2020
Hi i cant seem to connect this 5.1 system to my pc its Samsung HT-TP33 5.1
Edit: I want to use it as speakers for my PC
Home system ports:
Its working fine on my tv and i use Toslink optical cable but on my PC my motherboard doesnt have that
My motherboard is Asus prime b450m-a
Can anyone help me maybe im missing something and it can be connected without optical cable port if not can u guide me what adapters i need to buy to connect it anyway possible.
If you want 5.1 audio the only way is through the optical port. You will need to buy an add-in PCI audio card for your PC that has optical out. And whatever you have connected to it currently will have to be removed. That is unless you buy a toslink switch.
Can i connect it anyway possible i dont really need the 5.1 surround fealing. Can i just use them as regular speakers?
