Help with connecting to internet
ShadowsVoid
423
I am currently connected to my router (which supports both 2.4 Ghz and 5 ghz). I want to connect my PC via 5 Ghz but no 5 Ghz connections are showing, just 2.4. My phone however is connected to 5Ghz.
I have a TP-Link TL-WN881ND 300Mbps Wireless card http://www.amazon.co.uk/TP-Link-TL-WN881ND-300Mbps-Wireless-Express/dp/B006BSPTAQ/ref=sr_1_1?s=computers&ie=UTF8&qid=1416507075&sr=1-1&keywords=wireless+card#productDetails
I have the latest drivers, I downloaded the most recent one and the version matches the one with what I currently have installed http://puu.sh/cYDtI/183f829443.png
Can anyone help? 5Ghz from what I've heard gives out a much better signal.
I just checked out that card, it's only 2.4 GHZ. Ping isn't going to change and your bandwidth is going to drop the further you get from the router. I would stick with the 2.4 card that you have. You can always look at a wired solution, that's usually the preferred method for gaming anyways.
Download wifi analyzer on your phone and you can see how strong the 2.4 and 5 GHz signals are. It even has an audio feature where you can crank the phone volume and put it in the room where your computer is, then move the router antennas around and you can hear the signal beeping faster or slower for the signal strength.
The 300mbps model is for the 2.4 ghz band, you need the 600mbps card to support the 5ghz band. This is why your card does not show 5ghz, because it does not have a 5ghz radio on it.
5ghz is less saturated and has more open channels which makes it "better". The higher the frequency is, the faster the signal dies due to obstacles. You will have better performance while in close proximity of the router with the 5ghz band, but go through 2 non-insulated walls and it is pretty much done.
