Help with Console Configuration for Cisco 891w Wireless 8-Port Router
LedaOhio9
75
I am at my wit's end here...
I have found every manual for setting up a Cisco like mine but, not the correct 891w one.
https://www.cisco.com/c/en/us/support/routers/891w-integrated-services-router-isr/model.html
I am vaguely familair with the IOS console but, I keep gettig hung up during configuration.
What I really need is a step-by-step instruction website showing the commands to enter from a blanked clean 891w router.
Or, if any here are feeling generous and a wiz at this IOS Consol, I have teamviewer on that PC with it connected via Putty Serial. LOG IN AND HAVE AT IT!
...Frustrated
What's wrong with this manual:
Cisco Virtual Office – End User Instructions for Cisco 891 Router Set Up at Home or Small Office
It appears to show a wireless router, of 891 model number.
It doesn't specifically say 891w, but it would seem to be the same.
I wish I could get it to that point. It needs the IOS configured. Setting up the IP Pools, Interfaces, etc.
This router is blanked.. It needs configured in the IOS before you can get the GUI webpage to load.
You connect to the router via a Serial Cable and connect using PUTTY to access the IOS system.
Here is the PUTTY window and the...
command# show ip int bri
URL:
http://i1344.photobucket.com/albums/p647/Leda_May/Capture_zpszn3uogr4.jpg
Here's a video giving you a brief explanation of the commands one needs to know to set this up.
https://www.youtube.com/watch?v=3dCpBR-e63g&spfreload=10
