Recently I set out to build a powerful gaming PC in a small form factor. Its my first time building a PC after 6 years of using Laptops. I assembled this inside a Corsair 250D -
i7 4790K + Asus ROG Maximus VII Impact
MSI GTX 980 TI Gaming
16GB Corsair Vengeance
500GB Crucial SSD + 1TB 7200 RPM Seagate HDD
Corsair RM650 modular PSU
Intel stock cooler, 2x80mm exhaust fans at the back, 1x140mm fan at the front and 1x120 fan at the side to pull in air into the case
Everything fit nicely. Performance is as expected. But I am not happy with the cooling. I am using stock intel cooler now to see how it works. The temperature varies from 40-50 deg C on idle to 80-85 deg C while gaming. Room temperature is near 30 deg celsius. Almost every thread about 4790k suggests that those CPU temps are too high and unsafe. The high load temparature was even higher (100 deg C on 100% load), but it was reduced after I lowered the CPU voltage based on recommendations on this thread https://communities.intel.com/docs/DOC-23517
So I am thinking about changing the set up -
CoolerMaster Nepton 240M liquid cooler instead of stock cooler
Remove the 120mm fan to make room for the radiator
Change the front intake fan to a 200mm
Keep the the 2x80mm exhaust fans at the back as it is
What do you guys think? Will those changes work? Do my stock cooler temperatures even warrant an upgrade, given the small size of the case and higher room temparatures? Do you guys have any other suggestions for any hardware chagnes or anything else?
PS - I do not plan to overclock at this moment because I have no experience with overclocking. Also I think this system can pretty much handle anything thrown at it and more without OC.
