Help with cooling - i5-3570k
jason3460
6
Hey, I have a few questions to ask, but here are my spec's first:
Case: Aerocool Vs-3 Advance PC Housing ATX Black (yes, I need a new case)
Power Supply: Corsair Builder Series CX500V2 - 80 Plus
Motherboard: AsRock z77 Extreme4
CPU: i5-3570k - 3.4 GHz
Hard Drives: Seagate Barracuda 1TB, Samsung 840 EVO 250GB
Memory: Corsair Vengeance 8GB 1600MHz
Video Card: MSI GTX 760 Twin Frozr 2G Gaming OC
I want to overclock my CPU to get some extra power out of it, I don't want anything crazy like 5GHz, something around 4-4.5GHz would be fine. I also need two new fans for my case, one for the front and one for the back, the front fan should preferably have blue leds.
So my questions are:
1. What CPU cooler should I go for, I would prefer not to spend over £100 GBP(roughly $160 US)
I've been looking at, the
Cooler Master Hyper 212 EVO (120mm) - £24 GBP - $39 USD (which is only a quarter of my budget)
and the,
Corsair 120mm Hydro Series H80i - £64 GBP - $105 USD
2. Which case fan would be best for the back of my case?
3. Which case fan would be best for the front of my case (blue led) ?
Oh and does anybody have any suggestions for a new case for my rig, preferably something not too expensive and not white, with good cable management.
Thanks in advance, Jason.
why the H75 ? compared to the other 120mm options from corsair
will the 212 fit in my case? and what fan would you suggest to add to it ?
EDIT: Just saw on the manufacturers website for my case that the Height limit for CPU coolers is 158mm, the 212 requires 159mm, so do i chance it, or get a different cooler?
I found this on another forum,
"I have a aerocool vs-3 case which says : 158 mm cpu coolers are ok . However I use a 159 mm cooler hyper evo 212 which still leaves a little extra space in the case. "
Using the same case which I'm using, he can fit the 212.
and this guy fits a Noctua NH-D14 in the same case,
"OK GUYS smile.gif I got it and installed and BOOM it fits without any problems wink.gif I can also close side panels wink.gif"
I quite like the corsair closed loop water coolers, but if i can get a 212 which will give me similar results at a fraction of the price then i don't see why i wouldn't go with the 212.
