Help with Cooling setup.
shouden freud
52
Hi guys,
I have a i7 4770(non K), inside a cooler master K350, a couple of HDD and a ASUS DCUII GTX 760.
I was looking for cooling my system efficiently,
should I use an entry level water cooler to exhaust the heat from the rear of the chassis, and place a 120mm fan on the side panel for the heat from GFX card to dissipate, or place a fan on the bottom.
This was my Idea, can you guys suggest somthing better or should I roll with it.
I will not show you a full on custom system since you are new. I will instead show a more common closed loop system which will only cool the CPU.
Cooler Master Seidon or a Corsair Hydro-series. For your case, look at the🙁sorry net is very slow so this will be late)
Your case only has 120 mm mounts, so these are for those.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181036
(look at the top 4 for the bottom link or the ones that say "120mm" fan size)
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100008008%2050001333%20600036012&IsNodeId=1
Water Cooler should be good.
