Hey guys!
So, here is my current config:
Maximus Ranger VIII w/i5 6600k/16gb Patriot Viper DDR4 3400/Seahawk GTX 1070/Intel SSD/Corsair H100iv2
Running AI Overclock of 22%, base clock boost 105. Proc running right at 4ghz, memory is XMP OC'd by Asus, can't remember to what.
I just got a Carbide Air 540, and I thought it had more space than my current case, but alas, it does not.
So - here is the dilemma.
I have two radiators. The twin 120 on the H100i v2 and the single 120 on the 1070. In my current case, I am push exhausting out the top with the CPU radiator and push/pull exhausting from the main system exhaust fan with the GPU radiator using an additional Corsair 2350RPM SP120 High Perf edition, I have two Corsair SP120's pulling in fresh air from the front.
So, my question is kind of two fold, I'm not sure what to do here.
The way I see it, I have two choices.
I'm going to push/pull exhaust the CPU cooler with the new case, the fans are awaiting installation.
I thought about putting the main CPU radiator push/pull exhausting out the front, and the GPU push/pull exhausting out the rear main. That would leave two Corsair SP140's pulling in fresh air from the top.
The other thought I had was to push/pull exhaust the CPU cooler from the top, leave the Corsair 140 exhausting from the main rear top vent, and put the GPU push/pull exhausting in the top front, with a SP140 pulling in fresh air from the front bottom slot.
I am nervous that either setup will result in a "loop."
The exhaust/intake on the front seems more likely to do this even though the cool fan would be on the bottom.
I'm leaning towards the front/rear exhaust, intake from the top. Any issues or better ideas? As best as I can tell, the push/pull wont fit if I try to CPU top, GPU rear. I'd have to drop push/pull from the GPU which seems like a bad idea. It would also limit the rear exhaust airflow potential.
My 1070 is running a clean 37-38c in games right now.
Thanks!
Thanks!
