I have a nzxt phantom 410 case, currently I am using a hyper 212 evo as my CPU cooler. I have two outtake fans on top, one in the rear. An intake on the bottom, the side, and two in the front.
My issue is that next week I will be getting a corsair h100i liquid cooler for my cpu, and it is suggested that you push air through the radiator. The only way this is possible is if I make my two top fans as intake. to blow across the radiator. However Now I will only have one exhaust fan.
How should I set up the rest of my fans? Should I turn the side one into an outtake? but risk having no cool air on my gpu? or should I have my front fans as outtake? but hot air rises =( Im at a loss for what to do. Any tips for cooling and fan setup would go a long way and be greatly appreciated. Thankyou
