[SOLVED] Help with cooling
KeithK2006
82
I started building my pc like right now but I realized that my dad purchased the dark rock pro 4 instead of the dark rock pro and we weren't allowed to return it. Would it be fine to run this cooler with the one fan in the middle? Otherwise i wouldn't get enough clearance for ram
You are good.
Your cpu is not overly hot so cooling is not a priority.
Just the middle fan would be fine.
Some other options would be to raise the front fan higher if your case permits.
Or, remount the front fan to the back. I don't think I would bother unless cpu heat became an issue.
Lutfij
We're going to need more information. Please include/list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
Also, which Dark Rock Pro are you referring to? The fans on the Pro 4 and TR4 versions can have the front fans readjusted to a higher point if the rams are conflicting but my question is, what slots are the rams in on your motherboard?
You are good.
