Help with Corsair H100i Firmware
NightHawk87
208
Hello I just got my Corsair H100i water cooler & having Trouble finding Firmware for this can anyone help I see that alot of people have trouble with the other firmware update or something is that why I cant find it on Site??
How do I update the firmware on my H80i/H100i?
Please follow thes steps to update the firmware on your Hydro Series cooler:
1. Install the latest version of the Corsair Link software and use the "update firmware" button on the device tab.
2. Once Corsair Link exits a new dialog box comes up and you have to select "Corsair H80i/H100i" and then click back into the dialog box.
3. Use the choose file dialog box to select the unzipped firmware file.
4. Once you hit start it will flash the firmware and go through POST test on the H100i/H80i unit. The fans will spin up to full speed and then go back to the previous profile that was selected before the flash.
5. You can close the firmware flash dialog box and the program will open up...
ya ok cause I downloaded it the other day & Today I look at the Option & it said Firmware 1.0.0 & now its showing Corsair H100i Verison 1.0.5 it doesnt show firmware anywhere now so that make it 1.0.5 verison already firmware??
5. You can close the firmware flash dialog box and the program will open up again.
6. The service has to be restarted, so detection of the devices and inputs will take 15 to 30 seconds depending on how many you have. It will all come back up in the main program window as well as the de
Ok where do I find the Firmware?? cause I can't find it lol srry but I already have the Corsair Link installed & cant find the Firmware update anywhere it tells me to pick the file but cant find it!!
Im having trouble with this - I downloaded the LINK software from their homepage but I didnt get a firmware file included. Like nighthawk said it only tells me to pick a FW file, it doesnt have an "update" button, I have to find a file I dont have. Now, nighthawk seems to have fixed this but he didnt say what he did, and when I try to use the 1.0.5 file from corsair cooling forums I just get an error:
"Status: ERROR loading firmware file!"
Hmm what you mean bud? did you download file? & go to options on your Corsair h100i program on the corsair download site?? & load that file on firmware & update & restart your computer it worked for me!!
Thank you for your response btw. I downloaded the latest Corsair LINK from their pages, then I downloaded 1.0.5 firmware and tried . When I tried to apply the FW to my H100i, I get an error saying "Status: ERROR loading firmware file!"
Ya hmm that is Weird man did you just get a New Water Cooler?? & Was you having any Kinda Trouble with it to begin with?? You only wanna update Firmware if you're having Trouble with your Water Cooler!! I update mine cause I was having Fan Issues :/ Try Uninstall Corsair Link & start over again!! & Open up Corsair Link go to Options & Devices & look for Firmware if you dont see it in the Box click on Update FW & it will close out Corsair link & little box comes up just open file from Winrar dont Exract it or anything just Open it & should Update & tell you Its Good!! All I did and Everything worked!!
Good Luck man
