I just built my first PC rig, and once I was basically done I hooked it up to an HDMI cable to my monitor and connected the Corsair CX750 power supply to an outlet.
However, when I pressed the power on button, nothing happened.
I tried taking out all the plugs from the power supply that go into the Gigabyte
GA-Z87-DS3H motherboard and re plugging them in. Then I did the paper clip test to see if the power supply worked. It did. But, when I re plugged the 24 socket plug back into the motherboard and pressed the power button, nothing happened again.
Does anyone have any ideas on what to do? Does it mean that my motherboard is fried?
