I am using a B450M Pro VDH MAX motherboard and the SPEC-DELTA comes with 3 120mm RGB fans along with a single 120mm non-RGB fan. My motherboard comes with two SYS_FAN connectors and one JRBG1 connector. Do the RGB fans of the SPEC-DELTA come with a splitter so that I can connect them all to the JRGB1 connector?
P.S. I know I will need a separate splitter for SYS_FAN so that I can get them all to spin.
