Help with CPU cooler for Micro ATX
Eric Azure
23
http://pcpartpicker.com/p/PKkct6
I am debating between the Cryorig R1 Ultimate air cooler, or the Swiftech H140-X liquid cooling kit. Since the GPU's have flower style blowers I'm wondering what CPU cooler will give me the best internal temperatures and expel heat out of the case best. I will change to blower style coolers later on, or if i keep the H140-X then potentially add water cooling blocks to the GPUs later on. Opinions? Thanks.
Water cooling would be better, usually.
It will also expel heat out of the case well, as the tube is connected to the radiator, which sits next to the exhaust/intake of the case, opposed to a air cooler which sits in the middle of the case and depends on the fans on and around the heatsink to cool it.
