Help with CPU's
swaggaoriginz
14
Ok, so I want to get a CPU upgrade and can't find any 1100t's ANYWHERE.
So my question is, do I stick with my AMD Phenom II x4 840 or do I get an AMD FX-8150 3.60GHz (4.20GHz Turbo)?
I play games while recording and I render ALOT, my 840 just doesn't seem to cut it. So I am asking you guys for help.
ALSO If I buy a new AM3+ Motherboard now, will my 840 work OK in it until I can afford my 8150 if I was to buy one?
THANKS!
Unless you can find one on Ebay you probably aren't going to find any Phenom II's. AMD has stopped making Phenom II and Athlon II's.
I was thinking about it but i'm 15 and don't have a job... I getting my funds from pure luck. I could get and i5 if that's any good?
But is it good for recording and playing at the same time? Also, is there an AMD alternative to it?
Today, there are NO amd cpu chips that outperform their Intel counterparts in gaming.
Read this:
http://www.tomshardware.com/reviews/gaming-cpu-review-overclock,3106.html
Your X4 is about as good as you are going to get for gaming.
Multitasking and rendering is a different question.
Is your current problem with gaming, or rendering/multitasking?
What is the rest of your system?
For reference, your cpu has a passmark # of 2917
A FX-8150 is 8236
A 1100T is 6203
A 2500K is 6741
All at stock speeds. Add 20% for overclocking.
No there is no AMD CPU that can beat out the I5 or I7 processors. The Bulldozer is about equal to the Core 2 Duo which can be argued is on the verge of becoming obsolete. If you're going to be running different programs at the same time you would be better off with the I7.
Well, I currently have:
Corsair GS700
Amd Phenom II x4 @3.20GHz
ASRock N68 UCC
Radeon HD 5670
8GB 1333MHz RAM
BUT!
I am upgrading To a GTX 560 Ti So I Want a new CPU so I don't bottleneck it. And my problem is multitasking (Gaming/recording)
If you mean recording with a program like Fraps, your Phenom II should be good enough for that. A SB/IB i5 would be better, of course, but the extra performance isn't needed for just THAT use.
I vote for the 2500K, or the 3750K.
Either will OC to the same levels as the i7.
The extra threads on the I7 will not help gaming, but may help rendering/multitasking.
But The $100 or so difference is probably better spent on a graphics card for gaming.
