Help with custom building a gaming PC.
fuzzycobalt
8
Hello Tom's Hardware Community, I have no idea what I am doing. I am really new to this, but I configured a PC on the website "cyberpowerpc.com" and I would like some advice and assistance.
Really my goal is to make sure that it will work without melting, exploding, becoming sentient, spontaneously creating viral videos and the such. If someone could give me a hand it would be much appreciated.
Any advice on components I should change etc is appreciated!
Thank you so much!
http://www.cyberpowerpc.com/
Custom Configuration code:
1G9R4F
Gaming Chasis: NZXT H440 Silent Mid-Tow er Case w / USB 3.0, Modular HDD Trays, FN v2 fans included 3x 120mm front & 1x 140mm rear, Side-Panel Window [+54] (White Color)
Extra Case Fans: Default case fans
Noise Reduction Technology: Sound Absorbing Foam on Side, Top And Bottom panels, Power Supply Gasket, Anti-Vibration Fan Mounts
CPU: Intel® Core™ i7-4960X Extreme Edition Six-Core 3.60 GHz 15MB Intel Smart Cache LGA2011
CPU / Processor Cooling Fan: Asetek 510LC 120mm Liquid Cooling CPU Cooler - Enhance Cooling Performance (Single Standard 120MM Fan)
Motherboard: ASRock X79 Extreme4 ATX w / Xfast LAN, Charger, & USB, GbLAN, 3 Gen3 PCIe x16, 2 PCIe x1, 2 PCI
RAM / System Memory: 16GB (4GBx4) DDR3/2133MHz Quad Channel Memory] (Corsair Vengeance
Video Card: MSI Tw in Frozr NVIDIA GeForce GTX 780 3GB GDDR5 PCIe 3.0 x16 Video Card (Triple Card (3-WaySLI)
Power Supply: 1,300 Watts - EVGA SuperNOVA 1300 G2 80 PLUS GOLD Certified Full Modular Enthusiast PowerSupply
Hard Drive: 256GB ADATA SP610 SSD + 2TB SATA III Hard Drive Combo (Single Drive)
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
Internal Network Card: Intel Pro Gigabit 10/100/1000 Netw ork Card [+34]
USB Hub & Port: Built-in USB 2.0 Ports
Operating System: Microsoft® Window s 7 Home Premium [+104] (64-bit Edition)
I do not see anything wrong with the build. If you have the money for that monster, go ahead.
PD: Have you tried picking the parts on PCPartpicker.com and building it yourself?
Thanks for your help! No I haven't tried PCPartspicker.com, I'm kind of a gimmick goon and I liked how the other site showed me the stuff I was picking. Will PCPartpicker tell me if what I choose won't work with what I have selected? Like a compatibility function?
Pcpartpicker will tell you if the system will work, and what psu it reccomends! Great site, but ignore the pices, they do vary!
