Hi!
I have a problem with this graphics card, on an old machine and with these simptoms. The PC passes POST, but with all the text stuttering as it's being writen, then windows 10 Pro, boots up to what it should be the login. most of the times it stops there with the circulating dots. i can write the password while the dots are still "circulating", and it will enter windows, but disables the graphics card, installing Microsoft Basic Driver. Sometimes it shows me the login screen but still disables the amd driver.
Meaning i can't put the graphics card to run properly.
I've tested the card on other machine and it works fine.
I already did the bios upgrade on the mobo.
Can anyone has an idea of what i can do to make this gGPU work?
Don't have the money to buy a new mobo/cpu/ram, right now..
Thank you
Best regards!
Here are my specs:
MY PSU is a CORSAIR TX650W
Graphics
Monitor Name G2790G4 on Microsoft Basic Display Driver
Current Resolution 1920x1080 pixels
Work Resolution 1920x1050 pixels
State Enabled, Primary
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 64 Hz
Device \\.\DISPLAY19\Monitor0
ATI AMD Radeon RX 5600 XT
Manufacturer ATI
Model AMD Radeon RX 5600 XT
Device ID 1002-731F
Revision CB
Subvendor C.P. Technology (148C)
Current Performance Level Level 0
Technology 7 nm
GPU Clock 0,0 MHz
Driver version 27.20.1034.6
BIOS Version 113-D18903_XLE
Count of performance levels : 1
Level 1 - "Perf Level 0"
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type DDR2
Size 8192 MBytes
Channels # Dual
DRAM Frequency 399.9 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Command Rate (CR) 2T
Motherboard
Manufacturer ASUSTeK Computer INC.
Model P5Q (LGA 775)
Version Rev 1.xx
Chipset Vendor Intel
Chipset Model P45/P43/G45/G43
Chipset Revision A3
Southbridge Vendor Intel
Southbridge Model 82801JR (ICH10R)
Southbridge Revision 00
System Temperature 31 °C
BIOS
Brand American Megatrends Inc.
Version 2209
Date 11/03/2010
Voltage
CPU CORE 1.144 V
+12V 12.156 V
AVCC 3.392 V
+3.3V 3.360 V
+5V 5.088 V
DRAM 1.464 V
PCI Data
Slot PCI-E
Slot Type PCI-E 2.0
Slot Usage In Use
Bus Width 32 bit
Slot Designation PCIEX16_1
Characteristics 3.3V, Shared, PME
Slot Number 0
Thank you
Best regards!
Here are my specs:
Graphics
Monitor Width 1920
Monitor Height 1080
Manufacturer ATI
Device ID 1002-731F
Revision CB
Technology 7 nm
GPU Clock 0,0 MHz
RAM
Memory slots
Used memory slots 4
Free memory slots 0
Memory
Type DDR2
Size 8192 MBytes
Channels # Dual
Motherboard
Model P5Q (LGA 775)
Version Rev 1.xx
Chipset Revision A3
BIOS
Version 2209
Date 11/03/2010
Voltage
CPU CORE 1.144 V
+12V 12.156 V
AVCC 3.392 V
+3.3V 3.360 V
+5V 5.088 V
DRAM 1.464 V
PCI Data
Slot PCI-E
Slot Type PCI-E 2.0
Slot Usage In Use
Bus Width 32 bit
Slot Number 0
