sh: eval: line 0: Date: not found
Is my date!!
Can you help?!!
Thanks
Local Address: 10.103.0.36
Remote Address:
LogClient Log:
19700101 01:00:24 W WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
19700101 01:00:24 Note: '--allow-compression' is not set to 'no' disabling data channel offload.
19700101 01:00:24 W WARNING: Using --management on a TCP port WITHOUT passwords is STRONGLY discouraged and considered insecure
19700101 01:00:24 W WARNING: file '/tmp/openvpncl/credentials' is group or others accessible
19700101 01:00:24 I OpenVPN 2.6.14 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH/PKTINFO] [AEAD] [DCO]
19700101 01:00:24 I library versions: OpenSSL 1.1.1w 11 Sep 2023 LZO 2.10
19700101 01:00:24 I DCO version: N/A
19700101 01:00:24 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16
19700101 01:00:24 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20250617 15:01:28 W WARNING: if you use --mssfix and --fragment you should use the "mtu" flag for both or none of of them.
20250617 15:01:29 I TCP/UDP: Preserving recently used remote address: [AF_INET]212.2.238.214:1195
20250617 15:01:29 Socket Buffers: R=[262144->262144] S=[262144->262144]
20250617 15:01:29 I UDPv4 link local: (not bound)
20250617 15:01:29 I UDPv4 link remote: [AF_INET]212.2.238.214:1195
20250617 15:01:29 TLS: Initial packet from [AF_INET]212.2.238.214:1195 sid=c9d3025a ab2ad1b6
20250617 15:01:29 W WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
20250617 15:01:29 VERIFY OK: depth=1 C=VG ST=BVI O=ExpressVPN OU=ExpressVPN CN=ExpressVPN CA emailAddress=support@expressvpn.com
20250617 15:01:29 NOTE: --mute triggered...
20250617 15:01:29 6 variation(s) on previous 3 message(s) suppressed by --mute
20250617 15:01:29 I [Server-11618-0a] Peer Connection Initiated with [AF_INET]212.2.238.214:1195
20250617 15:01:29 TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
20250617 15:01:30 1 variation(s) on previous 3 message(s) suppressed by --mute
20250617 15:01:30 SENT CONTROL [Server-11618-0a]: 'PUSH_REQUEST' (status=1)
20250617 15:01:30 NOTE: --mute triggered...
20250617 15:01:30 6 variation(s) on previous 3 message(s) suppressed by --mute
20250617 15:01:30 net_route_v4_best_gw query: dst 0.0.0.0
20250617 15:01:30 net_route_v4_best_gw result: via 192.168.1.1 dev br0
20250617 15:01:30 I TUN/TAP device tun0 opened
20250617 15:01:30 I net_iface_mtu_set: mtu 1500 for tun0
20250617 15:01:30 I net_iface_up: set tun0 up
20250617 15:01:30 I net_addr_v4_add: 10.103.0.36/16 dev tun0
20250617 15:01:30 net_route_v4_add: 212.2.238.214/32 via 192.168.1.1 dev [NULL] table 0 metric -1
20250617 15:01:30 net_route_v4_add: 0.0.0.0/1 via 10.103.0.1 dev [NULL] table 0 metric -1
20250617 15:01:30 net_route_v4_add: 128.0.0.0/1 via 10.103.0.1 dev [NULL] table 0 metric -1
20250617 15:01:30 I Initialization Sequence Completed
20250617 15:01:30 Data Channel: cipher 'AES-256-CBC' auth 'SHA512' peer-id: 35 compression: 'stub'
20250617 15:17:33 2 variation(s) on previous 3 message(s) suppressed by --mute
20250617 15:17:33 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:55828
20250617 15:17:33 D MANAGEMENT: CMD 'state'
20250617 15:17:33 MANAGEMENT: Client disconnected
20250617 15:17:33 NOTE: --mute triggered...
20250617 15:17:33 1 variation(s) on previous 3 message(s) suppressed by --mute
20250617 15:17:33 D MANAGEMENT: CMD 'status 2'
20250617 15:17:33 D MANAGEMENT: CMD 'log 500'
19700101 01:00:00
https://ibb.co/Vcgd4xWd
https://ibb.co/1t9n8jZm
Is my date!!
Can you help?!!
Thanks
OpenVPN Status
StateClient: CONNECTED SUCCESSLocal Address: 10.103.0.36
Remote Address:
VPN Client Stats | |
TUN/TAP read bytes | 160 |
TUN/TAP write bytes | 500 |
TCP/UDP read bytes | 15370 |
TCP/UDP write bytes | 14500 |
Auth read bytes | 2004 |
pre-compress bytes | 0 |
post-compress bytes | 0 |
pre-decompress bytes | 0 |
post-decompress bytes | 0 |
LogClient Log:
19700101 01:00:00
