Warhawk373,
On behalf of Tom's Moderator Team, welcome aboard!
Here's the recommended operating range for Core temperature:
80°C
Hot (100% Load)
75°C
Warm
70°C
Warm (Heavy Load)
60°C
Norm
50°C
Norm (Medium Load)
40°C
Norm
30°C
Cool (Idle)
Guys,
There's a Sticky near the top of the CPU's Forum you should read:
Intel Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
RektSkrubz,
Respectfully, when users look up their Thermal Specification at Intel's Product Information website, they frequently don't realize what the definition actually means. Since there are many software utilities for monitoring Core temperature, users nearly always confuse Tcase with Core temperature.
Tjunction (Core temperature) is measured at the heat sources near the transistor "Junctions" inside each of the Cores by Digital Thermal Sensors (DTS), so Core temperatures are a minimum of 5°C higher than Tcase due to differences in the proximity of sensors to heat sources. Intel's Tcase Thermal Specifications are misleading, because Tcase is NOT Core temperature. The following is from the Temp Guide in Section 7 - Power and Temperature:
Tcase Specifications are
factory only measurements on the surface of the Integrated Heat Spreader, so Tcase is
not Core temperature, which is higher. Tcase values are also
calculated based on stock cooler TDP and processor TDP. Cooler models with
different TDP values are packaged with
different TDP processors. Several Generations of Quad Core CPU's at 77, 84, 88 and 95 Watts were packaged with a universal 95 Watt cooler. 6th and 7th Generation i5 and i7 "K" processors are 91 Watts, but the cooler is 130 Watts and is sold separately: Intel’s Skylake Cooler - http://vr-zone.com/articles/this-is-what-intels-first-cpu-cooler-for-skylake-looks-like/97189.html.
Compared below are three Intel processor / cooler combinations with respect to TDP and Tcase Specifications:
Example 1: i7 2700K 95 Watts TDP / Cooler 95 Watts TDP /
Difference 0 Watts / Tcase
72°C.
Example 2: i7 3770K 77 Watts TDP / Cooler 95 Watts TDP /
Difference 18 Watts / Tcase
67°C.
Example 3: i7 6700K 91 Watts TDP / Cooler 130 Watts TDP /
Difference 39 Watts / Tcase
64°C.
The higher the cooler TDP is from the processor TDP, the lower the Tcase Specification, just as when the stock cooler is replaced with a higher TDP aftermarket cooler, Core temperatures are lower.
Tcase is based on different combinations of stock coolers and CPU's, so Specifications vary. The examples above suggest the 6700K is less thermally capable than the 2700K, which is misleading, because the 6700K has a higher Throttle temperature.
Mobile processors don’t have an Integrated Heat Spreader, so they don’t have Tcase Specifications; only Tj Max. And since Intel changed the Thermal Specification for 7th Generation desktop processors from Tcase to Tjunction (Tj Max), this standardizes desktop and mobile Specifications. Intel's long overdue change signifies that
Tj Max is the limiting Thermal Specification; not Tcase. Your Tj Max Specification is shown in the monitoring utility "Core Temp" -
http://www.alcpu.com/CoreTemp
Tj Max Specifications vary from 80°C to 105°C. Some processors Throttle at 80°C, while others become unstable over 80°C. Core i 6th and 7th Generation CPU's have Configurable TDP (cTDP) and Scenario Design Power (SDP) which can trigger Throttling as low as 80°C. Although most processors Throttle at 100°C, it’s not advisable to push your CPU to the thermal limit, just as you wouldn't operate a vehicle with the temperature gauge pegged in the red zone.
If your processor is at or near Throttle temperature, it’s already too hot. The consensus among highly experienced and well informed system builders and overclockers, is that cooler is better for ultimate stability, performance and longevity. As such, all agree that it's wise to observe a reasonable thermal limit below Tj Max. So regardless of your rig's environmental conditions, system configuration, workloads or any other variables,
sustained Core temperatures above 80°C aren't recommended."
CT
