Help with dividing cores
jackrlehman
24
I have a i5-4460 and whenever I play bf1, cpu usage is at 100% and I get 15 frames. I have a GTX 970, so its not a gpu problem.
I was wondering if instead of BF1 using a single core, if I can divide the game into all of a few of my cores equally. Is there any software that can do this? If not can I do it in BIOS?
Thanks!
That is part of the basic programming of the game, there is no possible way to do this.
The i5-4460 should perform a bit better, also that game should be using more than 1 core anyway. I think this comes down to a configuration issue, or maybe some other sort of problem with your system.
