Help with drivers on motherboard
rednal16
53
Recently, I built my first gaming PC. So far, pretty much has been going smoothly besides when I try and install the drivers for my MoBo. When I try to do this, my ssd, that I have my OS installed on, doesn't have the bar that says how much memory is left anymore. Instead this shows. I know that this is a drivers problem because it doesn't happen until I install all of the drivers and restart. This is the website with the drivers . I was wondering what drivers do I need on this website for everything to function? A few of my components include i5 3570k, GTX 660 ti, Crucial m4 128GB SSD, and a 1TB HDD. Also, if you know what driver may be causing it, what is it so I can just not install it? All help is greatly appreciated!
What drivers are you installing? All you really need is the chipset, audio and the LAN driver. I have the same MB and most of the crap that AsRock has on that page is not only useless but it can actually negatively effect performance.
Can you give me some help in identifying the ones I need? (i.e. LAN driver is the 5th one on the list)
Realtek high definition audio driver ver:6559 - Audio Driver
Intel Management Engine driver ver:8.1.2.1318 - Chipset
Broadcom Lan driver ver:14.8.4.1 - LAN Driver
Just get those 3 and you'll be fine.
