Thew H440 would not be as good a choice for this.. I would recommend the Enthoo Luxe w/ built in fan control system for the fans, built in external LEDs and bult in LED control system.
https://www.youtube.com/watch?v=GdWXLAmmSjc
And what do you mean by a dual water cool system ? If you are you talking about two CLCs i would STRONGLY advise against that:
1. There is no CLC that cools a CPU better than an equivalently priced air cooler.
2. Every CLC I have seen had a cheap aluminum radiator and weak pump. To compensate for these deficiencies, CLCs need to use extreme rpm fans which are very loud.
3. Mixing aluminum rads with copper blocks is an extremely bad idea.
https://martinsliquidlab.wordpress.com/2012/01/24/corrosion-explored/
4. GPU hybrid CLCs cool only the GPU, leaving your VRM and other components no better and often worse than they were before. OCs are limited by the temperature of these items as much as the GPU temps... while the hybrid cooler make the GPU cooler, these other components now are the limiting factor of the OC.
5. For say a 6600k and GTX 1070, I would use
Swiftech H320 X2 -
http://www.swiftech.com/h320x2.aspx
MSI 1070 Gaming EK X -
http://www.tomshardware.com/news/msi-ekwb-watercooled-1080-1070,32104.html
Enthoo Luxe
Needed hoses and fittings.
You now have ....
- A 1.0+ gpm pump replacing the 0.1 gpm pumps found in CLCs, capable of pushing all necessary coolant thru the system
- All copper radiator with high heat transfer efficiency
-The system is expandable, you can add more blocks, more rads, more whatever you like
- A full cover water block which covers the GPU as well as VRM, memory and other components that need cooling.
- One powerful and efficient water cooling system, that cools all the necessary components with far less noise and potential issues than you would get with a dual hybrid.
