I have a Asus board with an Intel Duo Core E7500 cpu and 2 sticks of PC6400 1066Mhz ram on a Asus P5Q pro board with a Titan Fenrir cooler.
At stock speeds the temperature of the cpu is about 24C.
I have used the AI tweaker in the BIOS to set the FSB to 333MHz and the DRAM frequency to 1066MHz. This pushes the cpu frequency upto 3.65MHz with a temperature of 27C.
Every other setting is at Auto.
I have read on other forums that the E7500 can go upto 4Ghz with other changes in the BIOS, but as a newbie at this, I don't know what to change to be safe.
I am running CPU-Z, and it shows a core speed of 2008MHz with a multiplier of 6, but does change up to 3673MHz with a multiplier of 11, and a core voltage of 1.320v, where the max safe voltage is 1.3625v.
I did try the FSB at 400MHz, without any other changes, but my system became unstable after a short while.
The ram settings are FSB😀RAM 5:8, with timings of 5-5-5-15-52-2T, and I have not changed any of them.
Are ther any other changes I can make in the BIOS AI tweaker to push the cpu speed up a bit more, and maybe the ram speed, but still be on the safe side.
