Help with Entire Build
reblizz
https://pcpartpicker.com/list/9cLQsJ
Is the build I just did however when I finally started my computer up, only the top left of the motherboard is turning on and nothing else is. Additionally, my monitor isn't recognizing a signal even when I plug it into the motherboard or the gpu
The first thing is: DON'T PANIC!.
It's very, very easy to forget to plug in a cable or get one the wrong way round, particularly those tiny front panel reset/power switch ones, so run through each connection, checking it is secure and the right way round. And don't forget the CPU cooler cables!
