Help with Epson Stylus CX5400
jeff
1,172
Archived from groups: comp.periphs.printers (More info?)
I have an Epson Stylus CX 5400. Just replaced the black ink cartridge. Now
it wont print anything, just blank pages. The color cartridges didnt need
changing and I used an OEM Cartridge to replace the black. I have gone
through everything in the online instructions and instruction manual.
Nothing works. Just prints blank pages. Doea anyone have a solution? Thanks
in advance.
Jeff
If you email me and request the Epson Cleaning Manual, I will send you a
copy. It will probably resolve the issue you are facing.
Art
email at: e-printerhelp(at)mvps(dot)org
(at) = @
(dot) = .
> in advance.
> Jeff
You removed the tape on the cartridge of course before fitting it into the
printer.
Jan Alter
bearpuf@verizon.net
or
jalter@phila.k12.pa.us
"Arthur Entlich" <e-printerhelp@mvps.org> wrote in message
news:f7iPe.14323$Hk.8145@pd7tw1no...
> Art
> (at) = @
> (dot) = .
>> Now it wont print anything, just blank pages. The color cartridges didnt
>> need changing and I used an OEM Cartridge to replace the black. I have
>> gone through everything in the online instructions and instruction
>> manual. Nothing works. Just prints blank pages. Doea anyone have a
>> solution? Thanks in advance.
>> Jeff
Before you do anything, give Art a email, stating model and the fault,
ask him for his cleaning manual, he will gladly oblige and you will
find it's free of charge.
His Email is e-printerhelp@mvps.org you will find his posts
throughout these pages.
Davy
"Jan Alter" <bearpuf@verizon.net> wrote in message
news:amiPe.10669$Vg7.3172@trnddc06...
> printer.
There is no tape on the cartridge to the CX 5400.
It is reported a relative high percentage of the cleaning pump failure of
this series printers. I assume the pump isn't working correct.
Is it an actual failure of the purge/cleaning pump, or the fact that the
hose to the cleaning station from the cleaning pump becomes detached
that is being reported?
Art
In my opinion it could happened both.
If I remember correct you sent an image (hose loose from the pad). A user
could repair this failure easy, so sending it here it could be help Jeff.
Yianni
news:9pCPe.307814$5V4.2742@pd7tw3no...
> Art
of
>in advance.
>Jeff
Basically I have the same problem. How was yours resolved. I am going
through he cleaning process and I did reconnect the small
supply tube...I now qualify as a heart surgeon. It was not easy
reconnecting the tube without taking the printer apart.
My advice:
If you have a digital camera, take regular pictures as you take the orinter
apart.
I found it useful to remember what went where.
I did use a pdf document I found on the web useful, which showed the
exploded diagram of the printer.
If I find the link, I'll post it.
Terry
"L" <lc@xxxjoimail.com> wrote in message
news:UvYVe.12237$FW1.5680@newsread3.news.atl.earthlink.net...
Now
Thanks
> >in advance.
> >Jeff
In article <UMGWe.3389$Ob2.2348@newssvr12.news.prodigy.com>,
inkystinky@oem.com says...
I am a joke
> *HA HA HA HA HA WHAT A JOKE HA HA HA HA
> **HA HA HA HA HA WHAT A JOKE HA HA HA HA
>I am a joke
YES YOU ARE PECKERBLOOOMER
In article <9iiXe.358$OC2.164@newssvr21.news.prodigy.com>,
> >I am a joke
Wrong, as usual.
BTW, your caps lock is stuck on.
>>>I am a joke
>Wrong, as usual.
*YES YOU ARE PECKERBLOOOMER*
