Help with EQ2!
G
Guest
Guest
Archived from groups: alt.games.everquest (More info?)
Hello,
I wanted to ask this question here to see if maybe anybody else has had or
is having the same experience that I am with EQ2.
Just to give you some specifics on my system:
AMD Athlon XP 2600+ (Barton Core)
1.25 GB of PC2700 Kingston ValueRAM. (2x 512 [Dual-Channel] and 1x 256mb
strip)
MSI K7N2 Delta-LSR motherboard.
nVidia GeForce FX 5600 (256mb RAM)
1 30GB IDE HD 7200RPM (XP Pro Load)
1 120GB IDE HD (7200RPM 8mb Buffer) (EQ installed here)
NEC MultiSync FE991SB Monitor (Max refresh rates are [160Hz (V) and 96KHz
(H)]
I have Service Pack 2 installed.
I have DX 9.0c runtime installed.
I have the latest Nvida driver for the card installed.
I have tried running EQ in the following video modes (1024 x 768, 1152 x
864, and 1280 x 1024) - Refresh rate of 60Hz
I have tried setting EQ2 to High Performance to Extreme Performance but
never above High as I don't have that beefy of a machine.
The problem is as follows:
EQ launches just fine and I really have no problems until I actually get to
the character select screen or in the middle of actual gameplay.
However, sometimes the game will just freeze up on me. Nothing will continue
to move. I can hear the music and can move the mouse pointer but EQ2 won't
respond. This happens alot in-game.
Now, if I hit Ctrl+Alt+Del it takes me back to Windows and opens up task
manager. EQ2 is running in Windowed mode and it runs fine. Also, if I play
it in this mode, it does not freeze. I do not know what to do. Has anybody
ever had this problem?
Also, at times while in game - I will lose all texture detail and get alot
of crazy stuff on the screen but after about 20 seconds it will either clear
up - if it doesn't, switching to windowed mode fixes it.
Thanks for any insight. Wanted to try here before I tried to deal with
technical support.
Sincerely,
Aukua Huxley
"Aukua Huxley" <akhx@nospam.cox.net> wrote in message
news:yi1Hd.1747$ry.1022@fed1read05...
> Hello,
> strip)
> (H)]
> to the character select screen or in the middle of actual gameplay.
> continue to move. I can hear the music and can move the mouse pointer but
> EQ2 won't respond. This happens alot in-game.
> clear up - if it doesn't, switching to windowed mode fixes it.
> technical support.
> Sincerely,
> Aukua Huxley
I haven't heard of that problem yet. I'd send a bug report for starters.
Lou
