Mobo - Asrock Z97 Pro 3
Was using my PC, shut things down, installed a low profile USB 3.0 connector, covers back, plugged the PC back in, and then turned on. Before turning off, the wired ethernet connection was just fine. When I turned back on, no ethernet connection.
Error message when I go thru Device Manager and get into the connection is:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
So far, I have to no avail:
Restarted the PC;
Disabled, then enabled the device;
Updated the drivers, both locally, but then also from the web;
Uninstalled the device, then restarted the PC;
Downloaded and installed the LAN driver from Asrock's site.
Only thing I haven't done is removed the CMOS battery, but I'm too chicken to do that.
Anything that I may have missed? I really want to avoid buying a new motherboard, especially since I'm using a 4690k that has performed so admirably.
Thanks in advance for any suggestions or advice.
{Operation Failed}
Restarted the PC;
