Help with fan connections
ekard
23
Hello,
Total newb here in the middle of building his first PC.
I'm using the Aerocool DS 200 case and Asus Z97-A Mobo.
The Aerocool DS 200 comes with an inbuilt fan controller, a 120mm rear outtake fan and a 140mm front intake fan. I have also installed an extra 140mm intake fan above the front fan.
Should I install the two pre-installed fans to the fan connector? This is done via the molex connectors?
Then plug the extra intake fan into the mobo slot marked CHA_FAN?
The CHA_FAN connector has four pins, while the fan cable was only three slots???
Thanks.
You can plug 3pin fans into 4 pin connectors, just line up the grooves. A quick search on "using 3 pin fan connectors on 4 pins" will give you more info. Depending on the motherboard the fan may run on full though, some makes deal with fan speed control differently.
