Sup All,
I bought a CORSAIR Hydro Series H55 Quiet Edition Water / Liquid CPU Cooler 120mm awhile back. I tried to install the fan with it exhausting heat out the back of the case but it didn't fit. My case is Thermaltake v4 The exhaust part is about an inch taller than the case, is there a way to get that to fit into that case? Pcpartpicker lists the case as compatible so it should be able to fit in it. Would I have to exhaust out the top? Or am I just going to have to buy a new case?
Thanks
Thanks
