Help with fans 120mm
ShaDow_16
Hi guys, i would like to know if there are a way to put fans of 120mm on 140mm slot, I have an AiO cooler (NZXT Kraken x62) so I want put some cheap rgb 120mm fans on it because I can't found some cheap rgb fans of 140mm.. there are of fans 140mm of course but, from expensive brands like Thermaltake, NZXT or Corsalir something like that, so there are 140mm rgb fans cheap?? Or a way to put 120mm on 140mm slot..... For being more helpful please give me links.
THX!!.....
It depends.
If you want to attach it to the case, the case has to allow it by having the holes for it. Most cases will let you put 120mm fans in 140mm fan slots, but you should check the specifications first about what optional fan mounts there are.
Some AIO coolers MAY let you attach 120mm fans to them. But the Kraken x62 isn't one of them.
Something like the 3-fan pack is a bit more affordable for RGB fans, they aren't cheap because it's a bit more expensive to have controllable LEDs in a fan: http://pcpartpicker.com/product/6vfmP6/thermaltake-case-fan-clf043pl14swb
It depends.
