I have undertaken my first build and would like some advice. I have a cooler master 932 HAF and a ASUS Maximus V Extreme motherboard. It has 8 different 4-pin fan connections. I was able to hook up the cpu heat sink to the cpu fan 1 port with no problems, however a friend of mine was helping me with the build and connected the rest of the fans directly to the power supply, a cooler master silent pro 700 watt power supply to be exact. How would I connect the fans to the motherboard so I can see their progress in the BIOS? They only have three holes and the mobo has four prongs the case I have has 3 230mm fans and one smaller fan in the back if I disconnect them from the power supply and connect them into the motherboard will they still receive power? I understand this may be a novice question but I would appreciate the help thanks. Also where, if I do unplug the fans from the power source, should I plug them back into on the motherboard exactly? Thanks again
